Need a new sliding door/ door wall etc.
Sodbuster
1,526
Michigan
I've told myself for the last 3 years that I was going to replace our sliding glass door before the next winter, and it's still here. It's a Kolbe & Kolbe brand, that is around 20 years old. It leaks air so badly we need to put one of those window films over it, or you feel a breeze. Problem is, I start reading reviews, and according to their owners, all new sliders suck. Does anyone here have a good recommendation for a replacement that seals tightly, and is good quality. Thanks.
Not sure what they're called, but they have a regular type door with a large window panel next to it. They have to seal better than a slider. My slider leaks some, but not enough to be replaced. If it gets replaced, that's what it will be.
Thanks, will look into that, almost sounds like some sort of French door, with a fixed panel.
Glad to offer the idea - probably worth what you paid for it...==c
It dawned on me - look up "Patio Doors" at Home Depot.
Yes, I replaced both of my sliding doors with swing doors.
One has the door in the middle with half width panels on each side. The other is a French door with a full fixed panel on one side, this is a Pella door around $800.
The other sells for around $2500.
I hope you don't run into the same problem I had. The man that built this house didn't know what plumb is. One door opening was out of plumb by 5 inches from top to bottom. This explained the reason he used sliding doors.
3 years ago I replaces both my leaking slider doors with french doors
what a difference in performance . Wish I had done it years ago
We replaced the original 1970s vintage sliding doors with full glass French doors . . . they're much better.
When you guys say French Doors, I'm thinking of two full size doors, with one door being fixed. Are we thinking the same thing? The door that needs to be replaced, is by the dining room table and opens to a deck, so it would need to swing out, or hit the table. My parents had a door that they used to replace a slider years ago. IIRC it had 3 smaller panels, and only the end one opened. When the latch was thrown, it would also throw latches at the top and bottom to suck the door against the seal. Our door faces due north, so it gets abused by the winter winds. We've had storms where our plastic window seal was stretched out a complete foot in the center, tells you how much air would have been coming through. And we've had snow blow in as well :rolleyes:
Two doors . . . one opens regularly like any old door. The other door has a latch at the top and bottom so it is usually fixed in place, but if I want to open it wide open for lots of fresh air or to move in something very large I can swing it open.
Pretty sure you can get doors that swing in or out . . . depending on your wants and needs.
  • Need a new sliding door/ door wall etc.
We had a crappy French door type setup that leaked like a sieve. We did the opposite and swapped it for a reall nice andersen slider. Huge improvement.
Our 30 year old Andersen slider still seals well. I've checked it with an infrared camera. We use it often to let the dogs in/lout. I'm real picky about air leaks and have been pleasantly surprised by this door.
Sliders were/are popular for a reason. I've not liked the "sill" height of some french doors and found them awkward as entry doors when compared to a slider.
A patio door has a fixed panel with one panel that opens. A French door both doors are operable. Ours has the latch like y'all mentioned top and bottom the can be used.... So both too can be opened. Our are Pella Designer series.Luv em
In our former home we had the Pella des series French slider. Regretted it cause it would only open like less than 30 inches. So couldn't take anything large thru it like the real French door setup. That was my mistake.. my mistake. Cause we had furniture there the swinging doors would have interfered. Now we have the large slider in our other home walkout basement. Hope we get out of this rut and move there soon
thanks all
I have 4 big Andersons that have rotted out on the bottom that I have to replace. $1800 before install...each.
I've been putting that off.
Ours is aluminum.
I've been collecting discarded sliders for several years. One day I'll build a nice big green house with them all.
Not to worry, it's not next winter yet!
Spend the extra and get a quality french door, or save money on the door and spend more than the difference in lost heat & drafts.
Reactions: Sodbuster
Heavily leaning toward a french door, or removing the door altogether, we only use it for ventilation in the summer, a window would suffice.
That makes sense. Be aware that any window within 18" of the floor should have safety glazing (e.g. tempered glass) which is a more expensive window. That why you'll find most windows installed above that height.
