Been using a NC 13 for a couple of years now. It seems to burn hot! It has no problems hitting 700*-800* and burn time isn't that long to me... A bit over 2 hours..maybe 3 hours if I'm lucky. I'm burning 2 year old oak.
Last night I experimented with blocking off the rear intake. I covered it with
aluminum foil. Put a small slit in it with my pocket knife so it could still draw some air.. I had a much more controllable fire. I didn't time how long it burnt but it did seem a lot longer!
Side note... Before I started my experiment I did check the stove for leaks
and found none.
Is cutting the rear air intake a good thing to do or should I ????
and found none.
But for a reload, clear it, then let the ash settle until the next load.
