I am in process of building out backyard patio/yoga deck. I am building an 8' tall fireplace that has a see through natural gas fire pit with inset TV above on both sides. I did perimeter framing in treated 2x4 and inner near fire pit area with metal studs. The ceiling of where fire pit will go will be 1/2" cement board with porcelain tile. My question is the distance between top of fire pit and where the TV insert will be is roughly 13" Should I wrap insulation around top and sides of firepit walls to protect from heat? is a 36"x12" with 150k BTU
Note the steel studs is not completely framed out yet
