We are just starting our third season with a Napoleon 1400 Pedestal model. While I don't have a very extensive frame of reference or long years of experience with other stoves, we have been happy with the 1400. We burn it pretty much 24/7 from mid-December thru March and slightly less in the shoulder seasons. The only months it doesn't get used at all are July and August. It has a nice big firebox that allows for EW and NS loading which is very convenient. The viewing window is quite large and doesn't require too much cleaning unless I'm burning lousy wood when I close down the air at night. As far as burn times, I can't guarantee 8-10 hours although with well seasoned, hard wood it will probably be very close. Typically I load it full when going to bed (around 11PM or midnight) with big pieces and when I get up at 5AM or 6AM there are plenty of hot coals to get things going again with a few smaller pieces and wide open air. My chimney is quite long due to the design of the house. About 1.5 meters up from the stove, then about 1.5 or 2 meters horizontal thru the wall, and then 7 meters straight up the outside of the house. Everything is class A except for the first meter above the stove. It draws very well.
The ash dump isn't the most convenient as it is a rather small hole in the bottom of the fire box so I often just scoop ashes right out of the firebox rather than using the ash pan, but since we burn 24/7 this can be difficult so the ash pan comes in handy.
I installed an OAK although I probably don't need it in our extremely drafty house. The double layered top makes thermometer placement challenging. First I had it on the flue collar but that wasn't very accurate. Now I have put it under the trivet although it isn't as easy to see there, but I get more accurate temperature readings. The blower on ours is somewhat finicky, sometimes making squeaking noises but oiling it up has helped, and to be honest we don't use it all that much as the stove radiates heat nicely even without it and I have a ceiling ran right above the stove.
The stove was given to us and I don't know how old it is, but when it was installed the chimney guys (who also run a store that sells stoves) checked it over and everything was OK. That was almost exactly two years ago. This summer I discovered that the airwash shield was completely rusted out and crumbling so I ordered and just took delivery on a new shield and gasket and will be installing them in the next few days. The user's manual says to check this part every season so it sounds like it is considered an expendable item. But the replacement only cost $30 including the gasket so not a bad deal. I also ordered a new manifold shield even though ours still looks okay. This is the cover for the secondary burner and it is made of thin metal, similar to the airwash shield. The manual says to check this yearly as well. It cost $32.
Some of my bricks are cracked but don't need replacement yet.
If the stove you are looking at has a blower test it out, letting it run for 5 or 10 minutes at different speeds just to see how it sounds. Also definitely check those two parts I mentioned. The airwash shield is right above the opening of the front door, on the inside and is held in place by four little bolts. You would have to remove that part to check the gasket that goes with it. It is not the rope type but rather a large sheet of felt like material that is the same size at the shield and is held in place by the shield. I purchased those parts here.
http://www.ereplacementparts.com/na...e-with-legs-parts-c-182799_185675_185729.html
The attached photo is from when we first installed it two years ago.
![Napoleon 1400 Napoleon 1400](https://www.hearth.com/talk/data/attachments/184/184086-5840c412ed25136d12cc79dd0af15651.jpg)
