I
ISeeDeadBTUs
Guest
and I am blaming Eric today. All this talk of BlueForge and I had to go check out their website. Since the Greenwood is the only 'Wood fired Hydronic' I've ever run, I'm going to compare the two . . . .
1)Before I finally purchased the GW, I was concerned about no means to remove ash.
GW tells you it leaves nearly no ash behind. As with most sales bull sheetz, that MIGHT be true with PERFECT wood. As I've mentioned before, the GW will leave 'bricks' of compressed ash at the back of the box after periods of over-filling with wet wood. If you let the coals burn down a bit, you can pull the bricks out with a sod shovel.
Looks to me like the Blue Forge has a way to handle ash better than the GW.
Score one for BF!
2)The GW in non-pressurized (open system) which requires a HX of some sort. Everytime I read 'HX' i thin inefficiency.
Looks like the Blue Forge can be plumbed directly into an inside boiler and/or mixing station.
Score two for BF!
As with every other boiler out there, you never know until you run it for awhile.
One thing I have found with the GreenWood is that chunks at the front of the box are too far from the air intake to really burn hot when the rest of the chunks have burned down. The funny thing is I first came to Hearth.com looking for ideas on a 'ramp' to place inside the GW firbox which would force (by gravity) the wood and/or coals toward the air intakes. It looks to me like the Blue Forge would work better at this since the sides are sloped to force the wood and coals to the center.
Score three for Blue Forge![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
However. . .those of you that have run artificially aspirated boilers - forced air induction units - will probably say they are fine, but I think the simplicity of the GW makes for less to go wrong/malfunction. The Blue Forge looks like it has a downdraft forced air induction secondary chamber.
Score this one a draw between BF and GW.
My biggest concern with the BlueForge (remember, this is based on their website, I've never seen a BF yet) is the north/south loading. Is the back of the box refractory material? If so, the loading orientation is going to cause the box to disintegrate faster than the GreenWood- if that's possible! And how much of the primary combustion chamber is refractory? If it's all, like the GW, then the BF will probably also do well with less than ideal wood.
Don't score this item until I find out more about the primary combustion chamber.
So . . .anyone here have a BlueForge?
Jimbo
Score one for BF!
Score two for BF!
Jimbo
