so i got a trailer for free and i'm going to set it up for hauling wood ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
i'm getting ready to tear it apart this weekend and re-wire it and cut off the wood deck which is very worn out. i plan on using 1" angle iron and i'm going to weld on some sides and a drop gate on the rear and use expanded steel sheeting for the sides and deck.
the trailer is 4x8 and i figured i'd fab up some sides that are 3' or 4' tall. the tailgate is 4' long so i figured 4' sides would be nice for tossing split wood in there to move around.
question is?? how much loose split wood will fit into a 4x8x4 space. maybe a little less than half a cord? stacked it would be a full cord...and the trailer will not handle that much weight as it's only a single axle rated up to 1200lbs. so if throw in loose split wood...how much of a cord will i get in there. my calculations tell me that even a half cord might be pushing it (depending on how dry it is?)
thanks in advance,
Riggs
thinking something like this...just scaled down a bit in size. this whole trailer will cost me less than $300 when i'm done...and i don't mind only carrying 750lbs of wood at a time instead of paying $6000 + to carry a few cords...it's only 20 miles and i'm in NJ every single day for work anyway.
![my trailer...how much loose split wood and weight???? my trailer...how much loose split wood and weight????](https://www.hearth.com/talk/data/attachments/97/97193-abe6c47c15be6f8503b013dbffb612a1.jpg)
thanks in advance,
Riggs
