I have been working on the tank part time for a few weeks. I am getting close to putting the pieces together and filling it up with water. I made the L shape for 2 reasons. 1. You cant see in the pics but there is concrete on the bottom 1/3 of 3 walls. 2 walls are againts foundation wall. I only need to reinforce the front wall. I will reinforce the walls that have concrete holding the bottoms. The concrete was part of the existing basement.
Ambient Temperature in Basement 60* - 70*
Volume - Approx. 760 Gallons
Tank Material - 2x4 studs, 3/4" Vantek plywood, 16 penny galv. spiral nails, 2.5" & 3" deck screws.
Insulation - R 11 Fiberglass, 1" Styrofoam, 2" Foil faced , bubble wrap.
Liner - Polypropylene 45 Mil reinforced.
Hex - 800' 1/2" non barrier pex (should probably use barrier pex) ( 4 coils - 200" each), 2 - Zurn Pex manifolds,
80' 1/2 copper pipe for support, 6" uv rated Panduit tie wraps ( used UV rated because the temp. limitation was 210* instead of 175* for white tie wraps.
![My Tank construction and experimental Hex My Tank construction and experimental Hex](https://www.hearth.com/talk/attachments/th_storagetank005-jpg.179472/)
![My Tank construction and experimental Hex My Tank construction and experimental Hex](https://www.hearth.com/talk/attachments/th_storagetank007-jpg.179473/)
![My Tank construction and experimental Hex My Tank construction and experimental Hex](https://www.hearth.com/talk/attachments/th_storagetank013-jpg.179474/)
![My Tank construction and experimental Hex My Tank construction and experimental Hex](https://www.hearth.com/talk/attachments/th_storagetank014-jpg.179475/)
![My Tank construction and experimental Hex My Tank construction and experimental Hex](https://www.hearth.com/talk/attachments/th_greenfire030-jpg.179476/)
![My Tank construction and experimental Hex My Tank construction and experimental Hex](https://www.hearth.com/talk/attachments/th_greenfire031-jpg.179477/)
![My Tank construction and experimental Hex My Tank construction and experimental Hex](https://www.hearth.com/talk/attachments/th_greenfire032-jpg.179478/)
![My Tank construction and experimental Hex My Tank construction and experimental Hex](https://www.hearth.com/talk/attachments/th_greenfire033-jpg.179479/)
