Howdy y'all. Well I finally got the camera and new computer incompatibility problem worked out. I've made a public gallery so everyone can see.
(broken link removed)
Here are the descriptions:
1-4 Pictures of the misc. chimney and stove pipe parts
5- Looking down into the chimney
6-7 Stove pipe. Looks like there is a slip joint there?
8- Looking at chimney piece. You can see where it has been painted. I believe this portion came into the house. You can also see the brackets about 1 1/2 feet down the chimney.
9- Top of stove with the fiber blanket stuff. Should the blanket be moved all the way to the back end of the stove?
10- Air control knob. If you look closely you can see that the 1st notch is visible roughly 1/4" out, but it's pushed all the way shut. Is that correct? Or does it need some adjustment so the mark lines up with the body of the stove when fully shut?
11- Door gasket. To trim or not to trim the fray?
12- General picture of fire box
13- Fire box, right side, looking up towards secondary burn tubes
14- Fire box, left side, looking up towards secondary burn tubes
15- Fire box looking up at secondary burn assembly
16- Another shot of the chimney and stove pipe stuff.
Chatted with BeGreen and Roospike about the chimney last night. Thanks fellas. If you look at picture no.8 you can see how it's painted at the top. You can also see where the brackets attached on the pipe. Brackets are in the foreground in pictures 1-4. I think the previous installation used the brackets upside down and where the chimney came through to the inside of the home it was painted. You can also see the flimsy beauty ring that finished off the inside.
Also on picture no.8, is this the correct end termination? This is where the stove pipe was simply screwed to the chimney. Is that right?
I'm curious too as to the first piece of chimney pipe. It's the fourth one over from the left pictures 1-4, and by itself 6 & 7. Near the top there is a collar and some screws. It appears that this piece is telescoping? Can that be?
-Kevin
EDIT: Added more pictures to the album, but for some reason I couldn't get the order correct. Aggrrh!
-Kevin
