My Log Splitter
stanleyjohn
506
southcentral Ct
Your link does not work correctly to view pictures for me, just comes up as a organizational function.
Kinda new to Flicker! Try the link again:)
Yeah, never heard of it. However, I am not the most knowledgeable about ancient splitters. Only been using a splitter for 15 years, and even then did not know much about them until recently in trying to decide which splitter to buy for myself. Actually decided to build my own. Now, trying to decide on the welder to buy and the materials I am going to need.
Another thing to consider is that the splitter might be one that was built by somebody and the brand name is only for the cylinder. From what I have seen, it really is not hard to weld together a splitter once you learn how to use a welder. The internet is a wonderful thing.
Typical splitter before vertical & horizontal became popular.
Nothing wrong with them. Many home-made splitters built basically the same.
For me, so low to the ground I had to work on my knees, was hard on the back & bending over all day.
Should work great. Parts kinda generic if any are needed.
I bet it splits wood just fine ;) :)
My Log Splitter
Reactions: TreePointer
Whenever I see an old wedge-on-beam splitter that's low to the ground, my first thought is Lickety Splitter; but the one pictured doesn't have the "Lickety" look. I'd say it's a homemade job or maybe a frankensplitter with many new and old parts mixed.
I dont mind low to the ground! Getting older and cant lift like a 20 yr old anymore.It handles 20+ inch width logs with no problems! Its just my back that i need to worry about.:)
Yeah, I was anti horizontal splitters until I saw one with a hydraulic log lifter on it. Don't know if that is an option on your splitter the way it is, but it very well might be if the engine and pump can handle it and you learn how to weld. Now, I am trying to design a horizontal log splitter with a hydraulic log lift and hydraulic 4 way blade lift that I can work on completing down the road.
Atta boy fabs! ;)
To the OP, only tid bit of info I found.
As far as I can find, VAn Industries stopped making log splitters and similar units manny moos ago. There is no information around anywhere. I have located a Van Industries in North Carolina, Here is theri contact information. Maybe they might know something about the Van Logsplitter. At least they might have heard of then. Maybe a relative might have owned the company or maybe one of them mught have a copy of an Owners manual they could zerox off for you. You never know.
Read more: I have a VANN GUARD log-splitter made by Vann Industries, South - JustAnswer http://www.justanswer.com/small-engine/2p90b-vann-guard-log-splitter-made-vann-industries-south.html#ixzz2FHTfYE88
The link on that page takes you to 404 land so perhaps Vann Industries is now defunct.
Trade mark for VANN expired in 1992. Mfg of tobacco handling/harvesting stuff. Looks defunct as a company.
(my googlefu is strong)
Reactions: granpajohn
Well, heck. My family heirloom splitter has the same Vann Industries marking. Until I read through this, I thought Vann just made the ram. Mine is much smaller, but maybe the same ram. I'm told that the engine on mine is a replacement also (B&S 5hp).
Mine is probably from the 1970s, maybe early 80s. Will post a pic after the XYL gets home with the camera.
I like the full size tires and engine mounted "out of the way."
Thanks for all the nice input! This splitter works very well and hoping it lasts a long time to come! It looks well built,solid with no cheap parts on it.With such a long piston on it i can split two logs at one time which saves time.I stand corrected from my brother! The orignial parts look well built but the new engine is made in china but so far it runs well.
