Well it's been a long time coming, but we are finally at the stage of remodeling an old 1800's farm house and putting our Tarm in. I've had it for a while, and the house purchase had been hung up over previous owners divorce, etc - but finally moving along.
Its about a 3,000 sq ft house with old cast iron radiators. Had an old oil boiler that wasn't zoned. I added an attached garage and a large breezeway addition that will house a boiler room for the Tarm and a family room with the Accentra. The Harman insert will go through the wall and the back side will be into the boiler room so all venting etc is in the same general area. We added a 5-zone manifold and radiant floor heat in the addition w/ mixing valve. The 5th zone is a dump zone which will be in the garage, but will also have a thermostat if we decide to use it for that. We also put in a complete forced-air system both in the attic and basement for backup heat (propane) and central ac. I am pumped to finally have this project in the works.
These are some of the first pics as we are getting started - I'll be posting more as the project moves along.
Manifold going in.
Starting to get the insert fit. Need to get the zero clearance surround to finish up the roughing in. Boiler room is directly behind the insert, and garage behind that.
![My install - Tarm HS4.0 and Harman Accentra Insert My install - Tarm HS4.0 and Harman Accentra Insert](/talk/proxy.php?image=http%3A%2F%2Fi1304.photobucket.com%2Falbums%2Fs539%2Fmbx5r%2FFarmhouse%2FPellet%2F20140630_155951_Android_zpsda25b421.jpg&hash=7bb1cb3e9762f933a34516a9b5fd41e9)
Manifold going in.
![My install - Tarm HS4.0 and Harman Accentra Insert My install - Tarm HS4.0 and Harman Accentra Insert](/talk/proxy.php?image=http%3A%2F%2Fi1304.photobucket.com%2Falbums%2Fs539%2Fmbx5r%2FFarmhouse%2FPellet%2F20140629_191757_Android_zps0ed65e90.jpg&hash=b874e6f8a932179213efaf1bbc500922)
![My install - Tarm HS4.0 and Harman Accentra Insert My install - Tarm HS4.0 and Harman Accentra Insert](/talk/proxy.php?image=http%3A%2F%2Fi1304.photobucket.com%2Falbums%2Fs539%2Fmbx5r%2FFarmhouse%2FPellet%2F20140629_191437_Android_zps29b0ec1a.jpg&hash=780e0b7e1b25a7272255d23891346ac0)
