It should be a simple request, but I can't seem to figure it out, perhaps some of you can help me. With the help of this forum, I installed a used Harman SF 160 last year. Although everything works just fine, I can't seem to keep the fire running all night and simply feed it more wood in the morning. Is this common? I've never owned a wood boiler before. I run the same wood in my home Avalon Olympic wood stove so I doubt it's anything to do with the wood. I've tried continually turning down the temperature (now at 120 for the damper open temp) and the adjustment holes are almost shut completely.
Forgive the very basic question, but should I be able to load it with wood and expect to build a fire from scratch every morning? What should I check? Is it leaking air from somewhere else?
Thanks in advance.
Thanks in advance.
