Yep, Insulated and Stainless.............
It's an old milk bulk tank. 1250 gallon DariKool. One set of the cooling coils is no good so it's no longer suitable for milk usage.
I got some 2" pipe fittings (T304 Stainless) off of ebay and welded them to the tank. Also welded the holes in the manhole cover shut. One fitting on the bottom end where the bung used to be, two on top where the stirrer and washer holes were. Both holes in manhole cover welded shut. One of the top fittings is attached to a stalk that extends about 12 inches down into the tank.
I have since attached two brass gate valves to the tank and installed a reducer bushing in the other top coupling to attach to a hot-water heater for use as an expansion tank.
The bottom fitting and the top fitting with the stalk have a few leaks that I've found with the garden hose so I've still got a little welding to do, but all in all I'm pleased with it.....
Traded a garage door and opener for the tank!![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Pics:
The Name says it all:
Overview:
Side View:
Nameplate:
Manhole Cover with holes welded shut:
The Manhole and Gasket:
eBay Stainless Fittings:
Top fitting with stalk:
Bottom outlet:
Top Outlets:
Pics:
Overview:
Side View:
Nameplate:
Bottom outlet:
Top Outlets:
