My first time starting a fire top down.
The top down fire works especially well in a stove with the reburn tube design. In my downdraft cat stove... meh. It really needs the heat concentrated at the bottom of the fire to work right.
For a cold start I usually do an "inside out" fire, a few criss crossed splits with some paper and kindling in the middle. Works in the stove and fireplace equally well.
I also spent too many years stacking heavy logs on top of a pile of paper and kindling and watching it smolder.
I still use the teepee method, since I was a kid. It works well for me. One flick of the Bic, that quick. I also love the " Art " of fire making and tending.
So far, I'm in between. A layer of N/S splits along the bottom. There is usually a flat split in the center with a somewhat taller split to either side, making a small N/S hollow. A Super Cedar on the flat center split with some kindling E/W above it. If I'm doing a large load, then a top layer of N/S splits.
It seems to work, and better than starting at the bottom of the fire box. The times I've tried top-starts the fire does not seem to draw as well early on. Maybe it's the design of the stove, or maybe I'm not laying it quite right.
All I can say is.. all the wasted years! Why was I not taught this in scouts?
Good question. Top down starting makes for a less smoky campfire too.
Reactions: oilcan1001
I'll be the odd man out and say I've never liked doing top down fires in my stove. Seems like it just drags everything out way too long until I can close the air control down. Bottom up has always worked well for me in my stove. I could definitely see top down working better on those mild days with getting the draft going and avoiding smoke spillage but I use other methods to avoid that too. That said, I'll give it another shot this year. I think I try it once a year in an attempt to change my mind but just end up using my usual method.
Reactions: BillBurns
I've been doing only top down starts this season and completely agree that it works fantastic.
Virtually no smoke issues.
Load it
Light it
Enjoy it
Reactions: bigealta
If you didn't have great results try the "Combo Load" Modified Top Down.
Bottom row North /South row with some gaps between splits,
Middle Row East/West splits,
Lay small sticks, 3/4", 1", splitter pieces or whatever u have on top of Middle row to make a "platform" for Top row.
Place small splits East/West on the "platform" on the Middle row.
Make a Second "platform" of sticks/ splitter trash on the Top Row
Either use your favorite fire starter on this platform and/or pile more small kindling that will light Quickly.
Light it close the door and Reload 2-3 hours later on the hot coal bed.
No need to do anything else.
If u want it to light up faster just use smaller splits on the middle and top rows.
Should look something like this:
