So I got the stove going good , it was a full load of white oak, 1 year seasoned.
Secondary burn got to going very well, temps where up, so I closed the air control all the way.
Later on went back down and the top of the stove was pegged at like 900 and stove pipe temp was at 500.
I look at the fire inside and the secondary burn was going really good. So since the stove air was already fully closed, I went to my manual stove pipe damper and closed it all the way. I waited for a couple minutes and the stove pipe temp was going towards 550 and I couldn't tell about the stove top as it was already pegged at 900.
I tried opening the door to let cool air rush in but it seem to make the fire roar even harder so I shut the door that made me nervous. So I grabbed some aluminum foil and plugged the air inlets in the back of the stove bottom at each corner. Then there was small hole up front on the bottom that I put a piece of aluminum foil tape over it.
So after the stove air was shut off all the way , the stove pipe manual damper closed completely and all the other holes plugged, the stove settled down to 400 stove pipe temp and 750 stove top temp. I watched it for like another half hour and it maintained those numbers so I left everything closed off for the night and when I got up this morning had a bed of coals like 3 inches deep for a 8 hour burn.
But it was scary for a little while.
. The Castine will really take off if you've got wood stacked in the front of the firebox up near the level of the top secondary burn perforations. I've learned to not stack the wood higher in the front of the firebox than what you can load towards the back (that is, unless I want to). It just turbo-charges the secondaries like you would not believe.
