James02 said:
Ok, so....Had the "break in fire". Nothing great but did get the room up a few degrees. I did use some kindling type wood and it was admittedly less than seasoned. I know there won't be a chimney fire after one burn, what are the warning signs. How ofter should it bewas swept? I hopefully have bout a month left for my real wood to season.
Preventative warning signs: Pretty much looking up or down through the chimney and seeing a quarter inch or more of creosote build up . . . although I would say I wouldn't be too worried until there was maybe a half inch of build up . . . assuming it is the fluffy cotton-like wisps or burned popcorn look . . . if you're talking a glazed black sheen I would be very concerned.
Warning sign that you have a chimney fire in progress: May include some or all of the following -- flames shooting through the chimney, locomotive/jet sounding as though it is taking off in your chimney, the sound of rice krispies falling down and making tinkling sounds in your stove pipe, red-hot stove pipe.
My personal recommendation to new burners . . . check your chimney monthly and schedule or sweep it yourself when there is a half inch or so of build up. Since I have my own equipment and can do a sweep from the ground up in about 10-15 minutes (and I would never live it down if I had a chimney fire and the guys at the station heard about it) . . . I check and sweep monthly whether the chimney needs it or not.
