Whats the consensus on whether to place your stacks facing the wind or running parallel to the wind? Reason I'm asking is 2+ years ago, I placed 7 stacks in the field to dry and positioned all 7 facing the wind with approximately 12" between the stacks. All stacks were in full sun. Started bringing the wood home this past summer and found that the logs in the first 2 stacks were pretty dry from top to bottom and end to end, but starting with the 3rd stack, the logs closest to the ground and situated in the middle showed very little cracking on the ends and certainly looked to be a lot fresher cut. This area would receive the least amount of wind and sun.
So, I'm now starting to place stacks parallel with the wind so it runs along the face of the stack thinking the entire stack will dry more evenly. Like my inner wood, am I all wet on my thinking?
By the way, it was 100% hedge and was stacked on the ground. Your thoughts?
