I have the stove for about 6 years of late when I start the stove it will go for maybe a hour and then go out.I first thought the pellets were bridgeing but checked with a mirror not the problem. Lit it last night after 1 hour I heard the auger whirling but not dropping pellets I turned the heat up to its highest setting which increased the amount of turns the auger makes and finally after about 1 minute it began grabbing pellets and dropping again turned it back down to setting 2 again I could hear the auger turning but not grabbing pellets again put it up on high and finally it started grabbing pellets this is a big problem as the stove will go out if I do not sit there and do this procedure. Just wondering if the auger motor has gone weak and needs to be replaced I also read somewhere that the auger itself should be sharpened every so often which I have never done. Any advise would be appreciated.
Lower Bucks PA
Lower Bucks PA
