Last season the pellet stove worked perfectly until the end of the season, so first time trying to get it going, I am getting 4 red lights error code that it is supposed to mean missed ignition from the feed motor does not run. I emptied the hopper and I cleaned really well from the hopper and from the front, just in case there was something jamming it. Nothing unexpected came out of it, so I then tried to start the pellet stove again with the hopper empty to see if I could move the auger to help remove any possible pieces jamming it, but nothing really happened. According to what I found, I am supposed to:
-Inspect feed motor circuit (Hopper lid must be closed, vacuum switch must be closed, snap disc closed, and feed motor must be plugged in) Problem is I do not know how to make sure the vacuum switch is closed, snap disc closed... I think I can figure if the auger is still plugin, which it should since last season it worked, so I do not see how it would get unplugged.
Are there any videos out there that could be helpful?
Perhaps any other suggestions of what my problem could be?
I appreciate your help!
Steven
Steven
