Hi All,
I bought my Mt. Vernon in November 2013 and since then had little problems with it. I clean it weekly and then clean the whole system every summer. I burn Turman pellets.
Starting at the beginning of this season, I've noticed that the burnpot door doesn't close completely when an autoclean completes. I tried to throughly clean the burnpot. Still the same problem. I then greased the slides on the autoclean and it now autoclean runs without hardly any noise. Still the problem persisted. I took apart the autoclean and reassembled... nothing changed. I then pulled the whole stove out and took a look at the autoclean motor assembly from the back side. I couldn't find any loose screws (as another posted suggested) but there was some dust in here so I cleaned everything out really well. Still the problem persisted.
When I run the autoclean cycle it seems to run fine right up until about a half inch from being completely closed. It then seems to stop short of fully closing. I can easily push it closed with my hand.
The stove still seems to work fine, just the burn put is slightly open which causes some partially burnt pellets to sometimes drop into the ash pan. Other than that, i don't notice any difference so far.
I appreciate any help you can give.
-Sten
-Sten
