This winter will be our 2nd heating season for our Mt. Vernon AE Insert. It's starting to get a bit chilly in NH, so I thought it would be a good time to test out the unit to ensure everything is ready to go in a few weeks.
Last Spring, we had the stove professionally cleaned by our dealer and the only other maintenance I did was paint the interior with the stove spray that came with the unit. It also had a container of baking soda in it...if that helps with the troubleshooting. At any rate, when I attempt to start the stove I get a 'Check Ashpan' error. I removed the empty ashpan and vacumed a small amount of ash that had accumulated under / behind the tray. Tried it again and got the same error. This time I took the firepot cleaning tool and worked it into all the holes in the firepot to ensure nothing was caught. Tried it again and got the same error a few times.
Does this mean I need new parts? Last year the auto-cleaning made some noise as the metal moved around and this year I'm not getting that noise. Any ideas to try before I call my dealer?
Thank you!
Thank you!
