this is my second week with this unit, i am burning softwood pellets,manual setting,heat output set to max 5, flame hight -3 which is mid to upper diamond flame hight, some times it cycles a little higher then dies back down, convection blower set to normal, softwood setting, unit runs 2 + hours before cycling off, temp diff 2.
i am heating 2800 sq ft, 2 floors with no problem, 2 bags a day, outside air temp +12. i noticed tonight that the plastic pellet liner under the cover closest to the front of the stove where the heat exchanger is located is so hot that you can not hold your hand on it, is this normal?
