Hi all. I've got a new Mt Vernon AE (board rev C) for this winter and I've been very happy with how it has performed the last couple of cold days. (low was 15 last night.)
I'm just trying to sort out one last nit. If I put the stove on Auto, the stove will not run at high enough of a level to reach the temp set in the thermostat. Its a significant gap - for instance right now I have the thermostat set at 73 and the temperature is hovering around 69 (26 outside) and running on medium. there is some play in the number (a degree either way), but that's typical.
And this is the self reported temperature of the thermostat, so its not a calibration issue. Its also not a capacity issue, if I turn it to manual-high the temp zooms right up and the thermostat shuts down the stove. When it is warm outside just running it on low pushes it past temp and it shuts off and restarts fine. And if the gap is large enough, for instance when turning it on after the setback expires and it is 60 inside vs a setting of 73, it will run at high to close the gap somewhat but it slows down well before reaching 73.
It makes sense that it would try and keep the temp a little below the target to avoid wear and tear on the ignitor, but this gap is really big. It's also not that big of a deal - I really desire 69 or 70, so I have it set up at 73 and it works out. But it's just not right, ya know?
The house is hungry for BTUs, no doubt about that. It's an early 19th century farmhouse with period windows that is basically only insulated in the attic. (I'm working on that insulation project too - but the windows stay and I'm willing to suffer for them.)
It appears the auto mode is under-estimating the heat loss and won't crank things up to compensate.
Anybody else seen anything like that?
I noticed that too and didn't understand why sometimes the fan was louder than others. We have our TV hanging above it and you start to notice you can't hear it
