I want to make a sled to get the wood from the stacks to the unheated room I have set aside this winter. In the past I've moved the wood to my garage, but I also stacked it behind the garage. This year to eliminate a mess in the backyard I moved the stacks to the side yard outside of the fence. I will have to move it about 40yards across the snow to get to the sunroom. I plan on having two rows in the sunroom about 8-9ft long 4ft high, one active for burning and one "drying out more" then refill the empty and and draw from the other. I'm guessing one row for me will last about 2 weeks so refilling won't be that bothersome.
I plan on making a sled from some old skis I have in the garage. Somebody has to have done this before. Could you post some pics so I could see some tried and tested plans please. I'm thinking that the two skis will be too narrow for the weight and the middle will drag. To fix this I could build up the base about foot of ground level but that makes for some weak joints at the ski itself. Unless I used a 2X12 and put it on edge and ran screws every 3in or so giving a lot of weight distribution. Opinions?
Thanks,
Charlie
Thanks,
Charlie
