Moving Air for Whole House Heating
30WCF
1,025
North Carolina
My house is 1100 square feet. The living room , dining nook, and kitchen are somewhat open, and there is a hall leading off that has a bathroom near the junction. Down the hall there is a bedroom on each side and the master is straight off the end.
Our stove is in the living room beside a 6' wide opening that goes into the kitchen/dining, and adjacent to the bathroom. These areas heat ok, but the bedrooms stay cold. I keep ceiling fans running blowing up to circulate warm air down the walls. I have been considering cutting in vents and running duct work with a fan from near the stove to the master.
The Q is if this were a good idea, would you go through the floor and bring cold dense air from the bedroom floor and let it come out at the stove at floor level, or in the ceiling and move warm lofty air from the living room to the master and vent it in the ceiling?
Right now I run a box fan on the floor blowing cold air out of the bedroom and notice that it does draw warm air into the bedroom along the ceiling, but it is drafty because it moves so much air.
I would try a smaller fan at the doorway of the master bedroom. I have a very similar layout. I almost felt like you were describing my house there for a sec. A smaller fan will work better and be cheaper than in line fans and duct work. The bedrooms at the end of my hall will hold at 65-70 depending on what it is doing outside. If you do insist on running duct work I would run cold air down low back to the stove room. Maybe cut some vents in above the doors were heat can log jam. This way you don't have to worry about getting up in the attic and trying to insulate long runs of duct work that will probably still cool off anyway. Just my .2 cents.
Your small fan is moving what direction?
On the floor back towards stove.
