In a house with forced hot air system for hvac (oil
Pellet stove installed in the first floor of the house and adequately serves more than one half of the house.
The other half and the basement are not covered by the pellet stove.
I was wondering if I just turn on the fan (only the fan) will it help circulate the hot air around the house? Basically suck the hot air from the return ducts and pump it back through the supply vents?
I don't really know for sure if this is exactly what happens when I flip the thermostat to fan mode but I'm speculating.
I might try this once the weather gets cold enough to use the pellet stove.
This is one of those things where I won't know until I try it out but I wanted to hear some thoughts and opinions of those here.
My big concern is the basement that is completely not covered by the stove and I really, really would like to avoid pipe freeze/burst episodes, but I also don't want to run the oil just for this purpose when the pellet stove otherwise takes care most of the needs.
Thanks.
![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
Thanks.
