Hi,
I've found a BioMass 40 for sale which apparently hasn't been used, and I'm planning on purchasing it. I've been reading this site a good deal so far and I'll certainly be coming back for help with the install later, but for now, I'm trying to figure out moving it.
Both the current owner and myself have walk out basements, so we believe we'd be able to back a trailer up to it easily enough. And so I think that from what I've read, some plywood and some pipes will make it easy enough to slide it in and out. My main concern at this point is getting it on our trailer. My trailer doesn't have a ramp, and I know the weight listed is 1400 lbs. I don't have a tractor or anything that could pick it up either.
So I have few questions:
1) Is 1400 the dry or wet weight? I saw that it has a 40 gallon capacity and so that would be a change of ~300lbs that it might drop when not filled. Or is that always filled?
2) Do you think it's sturdy enough to lay it on its side? I think with some ratchet straps we would have a good method of lowering it down.
3) Can it be taken apart to some degree?
4) Do you have other suggestions? I've got access to a flatbed trailer or a box trailer with sides.
My family and I have been throwing ideas around about getting it up on there, but haven't figured anything out yet.
Thanks!
-Dan
Thanks!
-Dan
