Down on the ground in the pic on the left side is a pine I dropped last spring, I finally peeled my gloves off the stump last Nov.Might be a sticky clean up this time of the year![]()
I don't think it did but will check once this wind calms down for good. Last weekend when I brought it back from splitting the beech, I stored it down about six feet from where I originally do.Hope the tree didnt take revenge on the splitter.
Took a couple of quick pics, the wind gust only hit when you decide to go outside.Hope the tree didnt take revenge on the splitter.
Sunday will be a good day for cutting, in the low 40's with sun, winds about 8-10 mph. I usually move one splitter to a safe area if we have high winds moving in, looks like I'll go back to that.Looks like you lucked out this time zap. Good luck on the wind. It was not as strong today as yesterday but is supposed to stay windy at least through Tuesday here. I've never been a lover of wind...
We also had a ground cover of snow and it has been spitting snow off and on all day again. But the temperature is now up to 36 so not bad. Definitely will get cold tonight.
Wow, that was a close call! Just saw this post for the first time. You sure do have your hands full this summer, Zappy. With all that wood that's down on your property, I may have to load the saws and head up for a week to help out!![]()
Thanks Ram 1500. We've been working in that area the last two years, it seems like once we get it looking like we want it Mother Nature creates more work.Now that's a nice work area that you have there...
This had to come down because of some damage Mother Nature did earlier this year. We used the rhino with two tree savers,winch and the cable.
The drop went just like we wanted it to go, some went for firewood and the bigger part will be milled. I'll have lots of chipping to do from this.
The wife made a good call on this when she said it needed to come down, where it Y'd, it already started to split.
I'm not sure if I put this up but if you need to remove pine pitch from your hands just use veegy oil or canola oil, it takes it off without any problem.
I was always wondering why the bar never seemed to be real pitchy after cutting White Pine, I'm thinking the Canola Oil that I run in the saws for the bar oil helps.Or as I've always stated, Miracle Whip works wonders and it takes very little. One can also use margarine and there are other things that can work well too.
Yes, straight Canola Oil (Wesson) for the bar oil. This will be my third year running it (smokin gave me the idea) so far not a problem.Do you use straight canola oil?
