I have a Moreso 7110, flue set-up out of top, 6" single wall into insulated stainless chimney that transitions through wall outside to stand alone chimney (not masonry), ~17' in height. Stove serves as primary heat source in our yurt. So far this year we have been burning only ash, dry and seasoned.
Problem: Creosote is building up on the stove's ash pan door, pretty much all over in the ash chamber (below firebox). Particularly bad at the back of the ash pan chamber, almost seemingly climbing up into the firebox glazing the grate and appearing on the bottom of the vermiculite in the back of the firebox. Also, with the door open during a burn (which Moreso advises against), however, unavoidable during reloading - small puffs of smoke stream out the rear of the stove in a rear 1 inch circular opening that lays within a cut-out in the back panel cover.
Remedies already attempted: All the gaskets replaced with proper 8mm door, ash pan door, and 5mm flue collar, and ensured the glass is snug and secure and it's gasket still good and not overly worn, etc. Dollar bill tested all of the replaced gaskets, good to go. Also, ensured to the best of my ability that the baffle plates and blanket are all seated properly. Chimney brushed, swept, cleaned from rain cap to stove collar. Emailed Moreso, they say there stoves burn clean, creosote, etc should never appear in such a way. That was the translated response I received back.
Nothing to date seems to have changed the situation. After changing the gaskets and giving the firebox grate and the ash pan compartment and even the darn pan itself a thorough cleaning, after another night or two of fires, all the creosote is back. With the door open for a moment or two during reload, the small subtle stream of smoke out of that back inch diameter cut-out persists.
What is going on?!!
This is my first go round with a Moreso stove. We de-facto bought it with another property and brought it to our yurt because are old wood-stove was some inexpensive Menards' sold unit. Using the Moreso in the yurt seemed like a no brainer for efficiency and ease of use. Hell the Menard's unit never gave us problems, cheap as it was.
Anyone have experience with a Moreso stove similar to this? Any chance someone has experienced a similar situation with any stove that is comparable?
I do really appreciate any and all insight, thank you.
What is going on?!!
