I'm very green when it comes to woodburning. With the help of all the great forum posts on the subject, I've decided a Morso 2b is my choice to replace the old stove in a small house on my property. But as I'm getting ready to put in the order, I'm realizing I hadn't properly considered the differing features of the 2B Classic and 2B Standard, and I haven't yet found it discussed on the forum. I've tried to collect the differences below, but I have no practical experience with which to evaluate them.
Differences:
Differences:
- Classic has an Ash Pan (drawer?) - Another forum post educated me that the utility of these depends on whether they're well designed (and personal opinion). Is this one well-designed?
- Classic has a "heat exchanger" on top - To me, it doesn't look like it's designed for much more than looks. What do you all think?
- Classic is about 70% heavier than Standard, for a pure thermal mass comparison. So is it correct to think it'll hold heat substantially better?
- "Technical Burn Times" in catalog: 6.3 hours for Classic versus 7.7 hours for Standard. From the forum, I'm not focusing on the actual times, but this is a 25% difference. Should I care?
- Classic's flue outlet center is 12" from stove rear, Standard's is 5.5". Might not seem like a difference, but for my tiny house with existing chimney connector far from the rear wall, I'd actually get back some of that space with the Classic.
- Per my closest dealer, the Classic is 70% more expensive.
- I saw a comment about the 2B Classic needing higher draft to pull thru the heat exchanger. I'd hope what I have is sufficient.
- I saw a comment about cooking on the 2B Classic being a bit cumbersome versus other specific makes and models. I doubt I'll ever cook on it once the novelty wears off.
- I'm upgrading an old and damaged wood burning stove in a 350 sqft, single room house.
- I live in a mild winter climate with daily extremes, about a 35-40 degF change every day. In other words, there can be 10 degF nights but it almost always heats back up in the day.
- I estimate I've got a 16' length straight-vertical factory built 6" diameter chimney with double-wall connector on the interior. It's about 6' interior, 6' thru the attic, and 4' thru open air.
