Randal said:
I let it get to 450-500 (gridle temp) and the wood is fairly well seasoned.
I am right in thinking that even if the wood was not well seasoned, there should still be less smoke with the catalyst engaged?
Even with 450 - 500 griddle temp, the cat (and perhaps the sides and bottom of the stove) may not have come up to light-off temp yet. It usually takes around an hour, plus or minus a half hour, depending on... lots of things.
While you are learning, let it burn 1.5 hours before engaging the cat. If I suspected my cat was a bit dirty, I'd try to burn it clean before disassembling things (PITB). I might let a first medium sized load of wood go to coals, add more wood to build a second medium sized load, get that load going good (don't rush it
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
, then engage the cat. Probably around 1.5 hours before cat light-off.
Once the cat is engaged, temps needs to climb from 500*F to 1000*F before the cat is actually at operating temperature (~1000*F - 1700*F) and consuming smoke efficiently. This can take another 15 minutes or more depending on... many things. Don't rush things your first season of learning. You will love that cat stove your second year after you learn to light it off consistently. Better to engage it later and keep the cat cleaner.
I prefer a digital probe cat chamber thermometer. Takes all the guess work away. Costs a hundred bucks, though. With a free standing stove, you might be able to use one of those analog dial jobs just stuck in the back if you can see behind the stove. I think it's worth it. Less anxiety. Better performance. Critical temp feedback. Improved overall firing at all phases of a load's burn. Easy to keep cat at optimal operating temps. More heat. No danger of thermal shock (POP!). Less wood consumed. On and on. I wouldn't operate a cat stove without one!
Personally, I start my fires cleanly (little smoke on start-up), using a modified top down method (Mo's canyon between splits technique
. It takes longer to get things going, but there's almost never much smoke, even before the cat lights off. That way, I'm in no hurry, thermal expansion rate is moderated for new fires (less stress on stove), cat has plenty of time to heat up, and there's little pollution (smoke) before cat light-off.
If you didn't cut and season your own wood, or test it with a moisture meter, you are burning blind and may have damp wood. Happens to me more than I care to think about. Wood Men stories abound.
Good luck.
