Well I can't learn if I don't ask Right
So My PB105 has feed rate settings Why would you change them? What does it do?
I get that it feeds slower or faster depending on which way you turn it.
I started on 4 and had plenty of heat about a month ago I turned it back to 3 and still have plenty of heat.
I'm thinking now that the heating season is over and the only job the pb will have all summer is making hot water that I might try turning it back to 1 Or would it be better to keep the feed rate up and have a shorter burn time? That is if the feed rate changes the burn time much???
