I always liked the stove design feature that incorporates wood storage into the base, so I got the idea to cut down a couple of ceramic floor tiles to fit in between the legs.
![More Morso mods... More Morso mods...](https://www.hearth.com/talk/data/attachments/197/197831-97b6b483e1da7750763516e72f0e9730.jpg)
![More Morso mods... More Morso mods...](https://www.hearth.com/talk/data/attachments/197/197832-5abe16dd55f5067231818104d6d891d5.jpg)
I also inserted a split keyring into the hole in the grate riddler. It's low down and the contact area is small so it doesn't get hot enough to matter.
Before we had the walls finished off, I installed a cheap little $13 bath fan up near the ceiling...
...and ran an insulated duct down the wall to exit behind the stove. The fan is controlled by a multi speed switch. The heated air that rises to the ceiling by convection is drawn into the wall and brought back down past the stove to pick up more heat and circulate into the room..The angle of the pipe is adjusted to blow at the rear of the stove so that similar amounts of air move around each side as well as over the top.
![More Morso mods... More Morso mods...](https://www.hearth.com/talk/data/attachments/197/197834-3b3c809b793691ab830d25702bd621b9.jpg)
![More Morso mods... More Morso mods...](https://www.hearth.com/talk/data/attachments/197/197833-7fc5e26736820d216b9330db2000d3aa.jpg)
