I did not give enough info on the stoves the Lopie is a manually operated stove, the american harvest is computer operated, that may be the reason they say I can only use the pellet vent and not the 6" like I did with the lopie?
First of all, I'm guessing you're referring to your previous post about the 6039? You didn't mention anything in that thread about the exhaust system, so I'm not sure what you're asking here.
Whether a pellet stove is manually operated or computer controlled, the same pellet vent pipe is required. Don't know what you mean by " 6" like I did with the lopie (sic)".
BTW, who is the "they" you mentioned?
They is the maker of the American Harvest stove Which is U S Stove. The lopie had an adaptor to go from pellet vent to standard 6" stove pipe which is how i set up the lopie. So i was going to do the same with the american harvest I was told by US STove I had to use 3" or 4" pellet vent pipe only or the stove would not operate properlyFirst of all, I'm guessing you're referring to your previous post about the 6039? You didn't mention anything in that thread about the exhaust system, so I'm not sure what you're asking here.
