Hi guys
I'm new here, and don't know much about fireplaces and heating, so please give me a break for any stupid ideas, or questions I might ask. But, I'm pretty handy, and will be VERY appreciative of any advice you can give me.
I have a two-sided, see-through, gas log fireplace that opens into two rooms. I've been told that I must leave all the glass doors open (or closed) when in use, but since we sit in only one of the rooms (the den) about 95% of the time, is there any way that I can direct most of the heat into the den, and not have to waste the heat energy that goes into the other room? A couple of things I've thought about:
Closing the glass doors that go into the other room. (Must I really leave them open? What happens if I close them?)
Placing some sort of a heat reflector on the hearth in the other room, to reflect the heat back into my den. (If so, can I put it fairly close to the fireplace opening, and do I need to leave much open space around it - or can I almost close the fireplace opening off with it?)
Placing a small fan in the other room, aimed at the fireplace, to push heat back into the den.
Will any of these work? Or, do you have any suggestions and sources?
Thanks in advance for your help.
Gary (brngrp)
Gary (brngrp)
Finally, my question is, can these doors being closed when the unit is being used cause problem with the rubber internal parts in the gas valve as you stated above?
