I have a chimney located in the center of a 1 story home with a finished basement. The chimney is about 15 feet from any outer wall. 2 flues run up it. One flue is dedicated to a gas heater in the basement. The other flue is is dedicated to a wood stove on the first floor. I want to add a pellet stove in the basement. If I add a stainless steel liner to the wood stove and also run a liner from the pellet stove up the same flue and seal of with a chimney cap what would be the issue?
Any ideas otherwise would be greatly appreciated.
