There were no screens available for a single door fisher. Only the double doors.
CamFan,
I have a double door, wife is wanting to see the flames.
woody
Then you don't have a Mama Bear. What is the width of the top plate, so we can first identify your stove. 4 legs, pedestal, or no legs? Flat top or arched top doors? Grandma will have a door opening the same as Goldilocks, and the full size Insert. Door opening on those models will be 17 wide X 10 1/2" high.
Grandpa has it's own size screen. They were available in many styles and are held in position many ways. A picture of your stove front will help determine the correct screen needed. You will also need a damper in the pipe which is the only control you will have when open door burning. The damper is slowly closed until you see smoke at the top ready to roll in, then open slightly to avoid smoking inside, yet retain some heat. Screens are handy when starting fires, or if you have damp wood and need to get it going. Or Valentines day That's about it.
Coaly is right you do not have a Mama. the right approach is pictures and dimenisions like he said. I have Gma and Honey Bear screens.
CoDang, I am so glad Coaly keeps up with all this stuff.
CamFan,
woody
With the top being 29 1/2 wide I would say grandpa, but coaly has facts where some plants used larger parts than normal. Your picture does not show to me an extremly large top on a grandma. Your measurement of 21" for the firebox confuses me. If on the outside measure the width of the back of the stove from the outside of the angle iron legs. If it is 28-28 1/2" you have a grandpa in my opinion. Our cut sheets for the back was 27 1/2 wide, now depending on some construction methods the raw box could vary some, add the legs and you could get more variation but from leg to leg at the stove body should be close to 28" for a Grandpa. When these were made we did not have a qc person checking each and every step. We just knew we had to get them painted, check for any leaks repair if needed and send them out. I would say that was fairly normal for most factories making them in the 70's.
If you need to know more specific age etc you need Coalys help. He would know when the steps changed by fisher. I hope this helps
I will have to look. I have plenty of the grandma he posted I may have 1 or two gpas left. My wife wants me to hold onto 1 for some reason.
