Moisture Meter
firecracker_77
Went to Baileys online and their meters sell for over $100. This one at HF is $13. I think a trip to HF is in order soon. I wonder if they have meters and falling wedges in stock or those are internet only items.
http://www.harborfreight.com/catalogsearch/result?q=moisture+meter
I am dying to test wood that I have drying. I'll probably be greatly disappointed, but that is life.
Lowes....$30 General mm is the way to go....
Reactions: MasterMech
Amazon.com: General Tools MMD4E Digital Moisture Meter: Home Improvement
I bought this one . Its very durable I just found out . I was stocking the wood shed and garage yesterday and would split some random splits to make sure moisture levels were good . After lunch I left to run some errands and when I got back home I couldn't find the moisture meter , then i remembered I had left it on the toolbox in the bed of the truck . I ended up finding it 1500 feet or so down the road a little dinged up and missing the battery cover but still in working order . I checked it on splits I already tested and got the same results so I think the calibration is still good .
Reactions: firecracker_77
http://www.harborfreight.com/catalogsearch/result?q=moisture meter
They have meters and falling wedges in stock at the store here.
I have a HF meter and a General Tools meter one is as good as the other but, I like the HF better, it's smaller, fits in pocket ,and powers up quicker than the General Tools meter , oh ya it's cheaper :)
Thanks for the heads up!!! There's an HF about 10 miles from me. I used to think that place was bogus, but they sell cheaper tools for people who don't need professional grade. Not a bad idea.
I have a ryobi MM, works pretty good. Can't remember what I paid for it. Its not a typical mm where it has 2 probes coming out of the unit, this has two pads that lay against the wood. I like it
I have the HF meter, mostly just to play with. I'm pretty sure different species give different readings. Most of the readings I get seem in line, but cherry rounds sitting for six months shouldn't check at 16%, consistently.
Picked this one up from Copperfield, seems to do the job
Moisture Meter Moisture Meter Moisture Meter
Need to use a meter, depending how fresh, split and stacked. My cherry I cut back in April is 18%.
Just curious. Which do you like better? Burning wood or pellets. I guess pellets are easier in some ways, but no free pellet scores!
I know someone who put a Harmon in back in 2011. she and her husband really like it. They said they burn about $4 worth a day or so.
Pellets are easier but wood throws off more heat.
Please it is Harman.;)
I'm sure the HF one will be fine. No need to spend more that $15 these days. I've been using one very similar to this one for a year and it's fine. http://www.ebay.com/itm/Wood-Moistu...546?pt=LH_DefaultDomain_0&hash=item588d180c6a
You're wise to be getting one...
I got one shipped from Hong Kong off eBay for like $13 did not leave the house!
!!! That's a good bit of money right there!! Prolly cheaper than wood bout still $120 month!
The stove was $4,500 installed. Those suckers aren't cheap. They have a lot of technology going on to incinerate those little pellets.
I meant cheaper than. Oil???? Not sure what I was thinking?
Yeah...I hear you. I can burn natural gas, but I choose to spend the money on the hobby for the love of burning wood.
