OK, so was at Home depot buying paint for the wall we just tore up to do our stove install, and saw a pin type moisture meter on sale, so picked it up.
It's this one:
(broken link removed to http://www.generaltools.com/Products/LED-Moisture-Meter__MM1E.aspx)
seems to work fine. simple instructions.
Interestingly, everything I have heard on this forum told me that something I tried would not work.. that is testing the "outside" vs "inside" of a split.
I went to my porch rack, as randomly as possible picked out a split of cherry, maple, walnut, and some scrub thing that grows in and around a couple of sink holes on the back part of the property, that I never have figured out what it is, but it burns good. All this wood was cut and split and stacked in March of '09, as part of ice storm clean up. Stacked between trees, up off the ground with treated 2x'4s, along the edge of my "back yard".
The info for this meter gives it a range of 8-22% with a error margin of 2%, understandable, since that is it's minimum reading. I probed all four splits in several places, and then split them open, and did the same. All were 12 or 14%, and all were the same outside pre-split and inside on the fresh split face..
and it would appear my wood is dry enough.
It's this one:
