I tested some wood this morning for moisture content.
I cut about a 1" slice out of the center of a piece of recently cut and split hardwood and put it in the oven at around 225 degrees.
It weighed 10 ounces (wet weight) when I put it in and now about 8 hours later it weights 6.9 ounces (dry weight).
The difference, 3.1 ounces is the weight of water removed.
What I don't understand clearly is what is the proper method for determining the moisture content using this information.
A google search indicates there are two different procedures.
The wet method and the dry method - as I call them.
Depending on which method you use you get a big difference in the answer.
Using the dry method (weight of water removed/dry weight) the moisture content is 45%.
Using the wet weight method (weight of water removed/wet weight), the moisture content is 31%.
Anyone have an idea of what the proper method is?
