Looking for advice and info. I have a masonry wood burning fireplace. The chimney was modified by being took down to just under the roofline when a new roof was installed. I would like to install ventless gas logs using the existing fireplace just for occasional supplemental heat. It is my understanding that ventless logs do not require a functional chimney or damper. I would like to seal off the throat/damper with stainless steel, and then hook up the logs. If necessary I can cap the upper part of the chimney also.
Here is my issue: the chimney sweep i hired to inspect/clean the chimney and fireplace said since my chimney has been modified I have to use an insert(which I don’t want and already have purchased logs). They stated there are issues using vent free logs with the chimney and it must be rebuilt to code if using logs. I asked for an explanation and have yet to receive one on why I cannot use VF logs with chimney sealed off since no damper or chimney is required.
Am I missing something? it’s an open living area, not confined so no additional combustion air is needed.
Does someone have any knowledge on why this would be?
Thanks
Thanks
