Are there any choices of modern wood burning stoves which use an 8 inch flue outlet instead of 6? If so, which models/brands? Thanks
Lots of folks dump the exhaust from their stoves into old masonry chimneys that are quite large.
That may work for an older stove but not so well for more draft dependent newer stoves. Those that do this often come here to complain about their stoves drafting poorly and need to add a 6" stainless liner. The increase in pipe size shouldn't exceed 2x the flue collar area. 8" is ok as long as the chimney is tall enough to draft well.
A 6 inch liner in a metal prefab chimney or masonry?
Ok, thanks. Looks like there are quite a few. They are beasts....
Either if they are not safe or don't meet the requirements for the stove. So for a metal 8" chimney that is air-cooled a liner would be required, same for an insulated metal 10" chimney pipe if the stove has a 6" flue. Also true for an unlined 8x8 chimney flue or one that does not have proper spacing from the building structure and combustibles. (2" interior, 1" exterior).
Most are on the big side, but the Buck 80 is mid-sized at 2.6 cu ft.
http://www.buckstove.com/model-80.html#.Vm2vQY-BvCw
One should first verify that their chimney pipe is class A pipe. That is correctly temperature rated for wood burning stoves. If the metal chimney is class A rated 2100 HT then it is ok to use with the stove, but with some caveats. Those being the height of the chimney and the number of 90º turns in the smoke path. If the 8" class A chimney is 18' straight up then it should work fine, but if there are a couple 90º turns to an outdoor 14' class A 8" chimney there may be draft issues.Thanks. I was wondering how people deal with the scenario of replacing an older 8 inch outlet stove with a new 6 inch EPA stove when the metal chimney is an 8 inch chimney. Change the entire chimney to 6 inch or just install a 6 inch liner in an 8 inch chimney....
Gotcha, a bigger stove can be nice in some circumstances, but there are limits to bigger is better.Yah sorry I meant a bigger stove that required a 8" pipe would be better, not that putting a larger chimney onto a smaller stove would be better. If I could've fit an 8" liner I would've chosen a stove with a 8" flue. I wouldn't put an 8" liner in for a 6" flue.
This in reply to BeGreens post.
No if it has a 6" out let it is designed and tested for a 6" chimney.The 6" stove is almost certainly designed and rated by the manufacturer to be run on an 8" chimney.
I have many times and most other sweeps i know have as well. This is usually after they tried just running an increaser and it didnt work out. It does work sometimes and others it does not. But i would never recomend it and no stove manufacturer will allow itI was afraid of this, you may have been misled. Just about nobody has ever put a 6" liner in a regular, class a, metal, 8" chimney.
For all the hassle I would strongly consider selling the old stove and getting a modern one with a 6" flue connection. It will burn cleaner and use less wood. This may be particularly important depending on how Utah regulates wood burning stoves in the near future.
