In this seasoning firewood video from Portage & Main, he instructs to have moisture meter pins "cross" grain. I was under the impression that placing the pins "with" the grain was correct. Which is better?
With conductance meters, however, the electrode should be oriented whenever possible so the current flows parallel to the grain. At moisture levels below about 15 percent, the effect of grain direction is negligible. At moisture levels above 20 percent, readings across the grain may occasionally be as much as 2 percent lower in moisture content than readings parallel to grain.
Measuring with the grain is the preferred method for testing firewood. A MM works similar to an ohmmeter, except the reading is displayed in percentage of MC, rather than internal resistance.
My understanding is, a measurement across grain takes several growth rings into the reading which may be inaccurate for fuelwood. Some rings will contain more moisture than others.
Thoughts?
After going out and trying it both ways, I realized it only takes a couple of seconds to do both and haven't seen much if any difference - and to avoid confusion, I am talking about the moistire meter here : - )I do both, and never noticed a difference
Agreed, a scientific analysis of MC is overkill for firewood purposes. I should've mentioned earlier that I haven't used my MM in a couple years now... haven't needed it. This year's wood has been CS&S for two years, it's well cured.Inaccurate for fuelwood? How accurate do you think it needs to be? We're not burning just one growth ring we're burning the entire split.![]()
I think many times a MM doesn't tell the story the way it matters to us. With a MM it seems everyone looks for the highest reading at a single point of the split which is typically the middle. The number that matters to the stove is the moisture content of the entire split.
A MM is probably better suited for selling firewood - and inspecting delivered wood - than for determining if my own stuff is ready for the stove.![]()
Wise advice for those who plan to heat with wood for the long term, and have the room, but not really useful in the present. It's kind of like advising a down and out person, desperately looking for work to feed their family, that if they had a big bank account they wouldn't need to find a job so badly. Perfectly true, but does nothing to help them now.Even though I own a moisture meter and use it from time to time, you know what I'm gonna' say: "The best device for measuring the moisture content of split firewood is a multi-year calendar!"![]()
We cut all and process all own wood and it's all free, and we heat our house primarily (99%) with wood. We have never been 3 years, or even two years ahead with my wood pile, and probably never will be (We just don't have the room), yet we always burn wood that is <20% moisture content. A moisture meter has been one of our key tools in managing this.
As to the original question, I've never noticed any signification difference measuring with the grain or across the grain, much more important to getting an accurate reading is to make sure you split (or cut) the wood and measure the freshly exposed split (or cut).
I don't think anybody is "mad" or has hurt feelings. And what you say about green oak is perfectly true, but that doesn't seem to stop a lot of people from trying to burn it before it's had a chance to dry properly, does it? Problem is most of the people who burn that green oak don't own a moisture meter and are not aware of what seasoned wood really is.Don't much matter 'bout the now. Cut an oak now and mark your calendar 'cuse it'll be 3 years before it will burn well, no matter how down and out you are. If you are forced to buy wood or you split smaller, for necessities sake, then's the time for a moisture meter. Never said moisture meters weren't useful. And the calendar saying? Well, it's just a "good humor" saying I've always used. I didn't come up with it to hurt feelings of make folks mad.
I have a saying too, I like to say "if every novice wood burner was given a moisture meter, and shown how to use it, there would be a lot less ignorance out there about what constitutes seasoned wood". If they all had moisture meters it wouldn't take long for them to figure out for themselves that if they want to burn oak they are going to have to split it and stack it and let it sit for a few years. Of course, there are other types of wood besides oak.
The couple of percentage points difference between warm or cold wood, or different wood species that moisture meters may or not have really doesn't mater much if you are getting consistent reading of <20% or less. What really maters is when people try to burn wood that is >25% or 30% MC and they don't even know it because they have no tool for determining where their at.
It has not taken me long to learn that lesson. My MM tells me high teens to low 20's. My insert tells me "get to cuttin,' splitin' and stackin', Rookie.""The best device for measuring the moisture content of split firewood is a multi-year calendar!"
