E
elkimmeg
Guest
A post yesterday guoted a cost of $5000 for a chimney block chimney?
Here is a sample of cost a chimney block cost $7.75 ea and is 8" high
an 8/8 clay flue 2' long cost $9.20
an example of a 16" chimney block chimney would require 24 blocks and 8 flues
material cost of $387.60 missing is the motar and some cement ties all told the materials cost would be about $450 excluding labor
given one mason and a helper should be able to complete it in one day Mason at $50 per hr and helper at 25$ per hour labor cost $600 the entire chimney could be built under$1,100
now start equating that to a class A 16' chimney with a tee clean out box and your finding would be surprising
Remember for appearances appeal a combination of chimney block and brick construction also can be had For instance the chimney block could be used for a center location and converted for appeal to brick above the roof line The fire place location also could be brick and blocks passing threw the floors above. Not all situations need be class A venting within a building or even outside.
A word about the pricing I called my masonry supplier this morning to get these quotes.
there was a post a day or so back where the top of his chimney had been eliminated a chimney block or brick single 8/8 flue chimney ,may make the most sense and it should not cost $5000
