Minimum temperature at which you can use Teflon pipe dope?
Sawyer
608
Northern WI
Does anyone know if there is a minimum temperature at which you can use Teflon pipe dope?
It is too cold here to use PL400 so I cannot put the final plate down on the last wall of my enclosure; I have to wait for 10 degrees. I thought this would be a good time to install the black pipe on the Garn but it will be down to -20 tonight and just above zero (hopefully) tomorrow.
I plan to wrap the threads with Teflon tape and apply the Teflon pipe dope after.
Thanks, George
Just warm up the dope itself . As long as it spreads on evenly and doesn't clump up I don't see that you would have any problems.
There was a discussion in the forum within the last month about tape and dope. The answer from the pros was that you use one or the other, not both. I have had better (not perfect) luck with the dope, but I learned something about applying tape better. Black pipe at 0F? Sounds like fun! At least with copper you can warm your hands ;-p
I agree with keeping the dope warm and I think you will be fine. I know the pros in that discussion earlier said either tape or dope but not both but I don't agree with that. Someone last year suggested the tape & dope yields no leaks but I went with just the dope since my father-in-law suggested that too. Last winter we made just a simple loop to heat the barn and had about 4-5 leaks. We tried tightening and finally ended up tearind down a portion and doing the tape & dope method. My new primary loop this year is far more complex with probably 5 times as many fittings and I was a little worried about leaks. The only leak is had was a union that I somehow forgot to fully tighten. I would definitely recommend tape then dope (Rectorseal 5)
Real world meets theoretical world again! I'll try both.
I agree with everyone else keep the dope warm and you should have no problems..(Im the one that supported both tape and dope)
Thanks for the information, at least i will be able to do something in this weather. The good news is..........not one mosquito bite!
The quality of threads in many modern fittings is dismal compared to even 5-10 years ago (stuff being made overseas by whoever will make it the cheapest-being made with poorly set or worn out tools) and they seem much more prone to leaks.
I've taken to following the suggestion I read on here of dope-tape-dope-- and it seems to compensate for the poorly fitting threads.
Trevor and others, I would rather be safe than sorry. I called a licensed plumbing shop and they use both on black pipe. They too said the threads they cut are superior to supplied fittings at times.
If I was going to use both and I have before, its dope first and then the tape over it. I use Rectorseal no 5 nearly everyday and have so for 30 something years. Had a few leaks but not very many. As far as temps for use, keep the dope warm and you won't have a any issues. I work outside all the time in Maine so I've fit a pipes in below zero weather.
Hasn't anyone heard of wicking?
I use wicking and cover it with a permatex type of dope. Grip is one type.
That is what we use in the trades.
Dido for me, I used dope then tape on all of my black pipe. My only leak was on a fitting I forgot (ok maybe too lazy) to tape, luckly it was an easy fix.
Funny how temps can be relative, waiting for the temps to warm to 0*!
Good luck, glad my system is all inside. I remeber when I was installing my wife got the woodstove going a little too good and I was working in sneakers and shorts!
