Hi,
I did a search but wasn't exactly clear on how to apply the discussions to my situation. Please excuse me if this was covered and I missed it.
We are looking to install Rais 106 in a new house (soon to be sheetrocked). The flue will run straight up through the ceiling and out. The ceiling/roof is very low slope (1:12). there is no attic.
The design for the structure is quite simple, almost stark so ideally we would have the least amount of "stuff" up at the ceiling. In doing a web search I came up with the various minimum spacing between the stovepipe for both single and double wall, plus the reduction permitted if the surface is non-combustible although I don't fully understand how they apply when the pipe exits vertically rather than horizontally.
My first question is what materials qualify both as a practical matter (I won't set the house on fire if I use it) and legal matter (meets code) as non-combustible? I see Hartiboard, cement board and Wonderboard mentioned as possibilities but I wasn't able to locate what if any UL or other rating would be required to be sure any one material meets the code definition of non-combustible. Anybody know?
Since the design calls for the ceiling to be of one look if there is non-combustible material it would be great we could use a few sheets of it above the stove, do the rest in sheetrock and be able to skim coat the whole thing so that it all looked the same. This raises the further question as to whether or not the skim coating or paint would blow the rating on any material that was otherwise considered non-combustible?
Ideally we would use single wall pipe from the stove up to the ceiling box (because Rais makes really nice looking single wall pipe), have an noncombustible ceiling and a very small and simple transition box at the ceiling permitting the minimum set back from the pipe to the ceiling. What I am not sure of is what that setback would be at the collar (sorry I don't know the proper terms) for both single and double pipe. Of course I would be using an approved ceiling mount kit not just running the pipe through ceiling.
Any help would be appreciated. Thanks.
