I think I am going to pull the trigger on the Alaskan Mill III, 36 inch. Do any of you guys (jay,etc.) use this model? My biggest questions seems to be the first cut, do you make your own jig using 2X4s or did you buy the rails (seem expensive for something pretty simple). Also does anyone use the Mini-Mill for cutting the ssides? Or do you roll the log and use the Alaskan Mill? Finally I see the 850 Slabbing Rail option that you can use with 2X4s, does anyone use these? I was thinking you could just use some adjustable metal strapping that you buy at the box stores.
