Milling Question
ladder or 2x8.
smokinjay said:
ladder or 2x8.
smokin thanks for all the help so far, how do you hold it down plus level it.
Zap
straight,flat Doug Fir 2 x 12 7ft long with 1/4" thick 2" x 2" angle iron full length screwed to each edge of bottom side for stability & help keep it true.
Leveled across with 2ft mason's level,length-wise with level resting on top of 2 x 4 with no warp,bow or twist.
Anchored to log with 3 #10 x 3" square head screws.
zapny said:
smokinjay said:
ladder or 2x8.
Zap
Same as thisle, and a Cordless screw driver. Sheems can be pretty handy at times.
At a couple GTGs a guy cut our cants before the race and did it pretty much same way.
Thistle & Smokin thanks but one more question, can you use this system (36 inch) with the ez rails you can buy?
http://www.baileysonline.com/itemdetail.asp?item=46778&catID;=
Zap
You sure can. You can get a package deal at Bailey's (Mill,double end bar,helper handle,aux oiler & ez rail system) for a bit less than buying each item separately. Also direct from Granberg International,not exactly sure what their price is for the set.
