brider said:
I'm looking at the S-4 instruction sheet for the Metalbestos roof support kit, and have some basic questions that really apply to any similar installation:
Do I install the roof support, THEN determine what length connector I need from the stove collar to the ceiling support?
The instructions say " twist lock additional lengths of chimney to top of assembly pipe to required chimney passes through roof and at least 2 feet higher...". This is verbatum from the instruction sheet, I assume it is just saying to NOW install the required height of chimney pipe. My question is the "twist lock" statement; do all chimney pipes have a twist-lock feature?
I can help!
I just did an install the other day which required some research in chimney pipe. Twist lock feature depends on the brand. Desa brand double wall pipe pushes and sorta snaps together (6-inch inner diameter by 10-inch outer diameter, non insulated, instead has 2-inch air way between the inner and outer pipe). Rick mentioned his brand was twist lock. I can vouch that MetalFab and SuperVent brands also twist lock. SuperVent pipe has a simple little band to keep the joints from coming untwisted. According to how I read the book, SuperVent's band is only required on connections above the roof line but can be used on all connections.
I used the SuperVent pipe.
For clairfication - I am defining the roof support as the black device seen above the stove that attaches to the ceiling and looks sorta like a simple light fixture.
Install the roof support first.
In the case of using SuperVent - set the first joint(s) of pipe into the roof support. At this point just install the entire chimney if you want and be done with all the roof work. Put the connector pipe adapter in place. It will twist lock in from the bottom of the roof support which is above the stove. Put the stove adapter on the smoke outlet of the stove. Put on your Super Man cape and scoot the stove in place (don't forget to tie your shoes). This will show you how much connector pipe is needed.
MetalFab pipe is similar. I just don't know how the connector pipe adapter goes on. I am led to believe that the roof support has the connector pipe adapter made into it.
At this point I wish to recommend one joint of telescoping connector pipe in addition to any standard lengths if needed. Some telescoping lengths are good from 30-some-inches up to 68-inches. It makes installing the connector pipe a quick, easy, and neat looking job. If you need to dissconnect the pipe, for cleaning as an example, the telescoping pipe makes that job so much easier as well.
Also, remember to ask if a stove adapter is needed for your connector pipe.
Also again, check the stove manual. It may have a minimum length of pipe required to produce enough draft to operate. My Lopi Leyden required 15-feet of pipe. I assumed this length was measured from the stove top to the chimney top. In any case i have 6-feet of chimney pipe towering over the house. My wife declared it to be a lightning rod. My kids what to install a blinking light on it.
I just hope I don't have to chase bats out of it.
https://www.hearth.com/econtent/index.php/forums/viewthread/23282/
