The topic of "What stove should I buy" comes up a lot.
A pellet stove by its very nature is a "Space Heater". Granted these stoves can heat a fairly large area but the question is can the people living in there be comfortable???
Sizing the stove can be tricky
Get a good all around stove that can heat the house completely (total sq ft) and during the shoulder seasons everyone swelters.
During the cold season, the room that has the stove is cozy but the res of the house is freezing.
To use the HVAC furnace fans to circulate adds cost to the overall picture and does not work all that well to distribute the heat.
A small house that has one main living area can in most cases do fine with one stove.
A two story home thats insulated well can likely do fine if the heat will rise up a stairwell and heat the upstairs.
A large rambling Ranch style home is a different story.
These "Barns" are a real challenge to heat even when they are insulated well.
I decided early on after buying a triple wide manufactured home with all electric heat that the pellet stoves were the ticket.
Our current setup is this.
We have a Prodigy II in the living room (SW corner)
A Quadra fire 1000 in the living room (NW corner)
An Advantage II in the family room ( NE corner)
The Advantage is sitting upon a raised hearth to allow the stove to blow warm air over the top of the furniture easily and down through the length of the house.
The following pics show a view from one end to the other. (you can see the kitchen breakfast bar as a reference point)
I am standing in the Dinning room and shooting into the living room, showing the Quad and the Prodigy.
The dining room is to the left of the Breakfast bar looking toward where the Prodigy is sitting.
Granted, not everyone has the room for multiple stoves, but in many cases the task at hand can be better accomplished using two or more stoves.
The results for us have been great.
When the outddor temp is in the low 50's F the Prodigy will keep the place quite cozy.
Let the temp drop to the mid to upper 40's and the Advantage alone does a right fine job.
Once the temps fall to the 30's and on down the Advantage and the Prodigy work in tandem to keep the place comfy.
Keep in mind that I am not stoking either of these stoves up on the upper settings.
Tonight both are running on the lowest setting and the house is at 70F (35F outside and likely snow by morning)
If the temps drop way down (teens) the Quad may be needed to help a little. Dont know yet as we have not had any weather that cold since the Little stove was added to the team.
Sizing a stove can be a tedious task, too big and it runs you out of the house, too small and it can't keep up when its cold.
I dont like to see a stove having to be run on the max setting to be able to heat the house.
I prefer the low to mid settings for 24/7 Duty.
All stoves are rated at a BTU output level (maximum)
The ratings will usually give a "from X to Y" ( 8500-35000 or some such ###) and this will be from the low to the high heat settings.
Just some thoughts and ideas as to what can be done. A small house can be a challenge to find a spot to put a stove thats not in the way.
A larger house can be a challenge too, things like stairwells, decks and such can make direct venting a real interesting situation.
I hate the idea of chopping holes in the roof for chimneys so I went with the direct venting on all 3 of the stoves here.
All work well with ZERO smoke back in the house, even during a power outage.
Hope this gives some newbies to the pellet stove world some ideas or at least alternatives.
Dont be afraid to think used stoves, so many folks simply dont use their pellet stoves for more than esthetics and then sell it a few years later for very good prices.
I paid $200 each for the Whitfields
The Quad was purchased new in 1993 for $1000 (floor demo model, with little use)
Snowy
Snowy
