Mendota DXV45 fireplace was installed last year. Worked great all season. This year turned on the gas, set to CPI, igniter ticks once/second. Pilot lights immediately. After about 30 seconds the pilot turns off. This cycle repeats. The igniter was still clicking every second all while the pilot was on. I am assuming the flame sensor (sensor with U loop at end, I assume) is not sensing the flame. I notice that the center part of the pilot is not touching the flame sensor, and I don't recall if it is supposed to be (can't recall what the pilot looked like last year). I did notice that there is a thin coating of soot on the burner tubes which I had not noticed during operation last year, so I assume the shutter needs to be opened more.
So my question is... on the assembly in the pic, is the center part of pilot supposed to engulf the flame sensor loop? If so, what would cause the pilot to not reach (assuming no change in gas pressure from last year). If it is not supposed to engulf the loop, could the soot have caused a pilot hood or flame sensor issue? Is it easiest just to replace the entire assembly or just the flame sensor? After only one year of operation, I should not have to replace anything!
![Mendota pilot won't stay lit Mendota pilot won't stay lit](https://www.hearth.com/talk/data/attachments/284/284873-ac81fe66c2afe23beefbb7bc9c572acc.jpg)
